6 volts or 12 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2004, 09:57 PM
New Member
6 volts or 12
Seems like a no brainer, but I purchased a 6 volt car with low miles, and all is well in the electrical system. Everything works as designed, has a new 8 volt battery. My only problem is that I have no cruising tunes. I can't find a 6 volt am/fm, cass, cd radio for my car. Somehow I doubt that I'm the first to go thru this. What are my options?
Thanks for your time
Old 11-29-2004, 10:05 PM
Old enough to know better
12 volts or an IPOD
Old 11-30-2004, 12:26 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
a 12 volt conversion isn't that hard to do, do a search in this forum, a few members describe how its done.
Old 11-30-2004, 10:59 PM
Seriously, unless you are shooting for a show-level restoration, changing to a 12 volt system is a good move. Every accessory in the world is 12 volts, you'll be able to buy light bulbs at Checker, and easily use an alternator which will keep your battery in better condition.
You really don't want to get into replacing an 8 volt battery.
Old 12-01-2004, 01:52 AM
Last journal entry: Got the backside done (more or less)
If you don't want to convert your entire system, check this out...
http://www.powerstream.com/dc6-12.htm
Old 12-01-2004, 07:13 PM
New Member
Thanks guys. I'm not sure which way I'm going to go. I agree that 12v is the way to go. But I have to be careful, because I have this bad habit of grounding a car for 2 years. I start by switching to 12volts, next thing I know, I'm sanding and buffing a base/clear frame. I promised my wife we'd get to enjoy this car, after a select few body, and suspension mods.
Old 12-04-2004, 05:08 PM
46wheezy's Avatar
Install the 12v radio. Run the power wires to a 12volt small lawnmower battery. That will probably be enough for your cruise. Throw it on the charger when you get back home .
