-   -   60-66 Front Crossmember swap with 73-87 (http://www.hotrodders.com/forum/60-66-front-crossmember-swap-73-87-a-227462.html)
Valkyrie5.7 12-22-2012 01:50 PM
The question pops up every once in a while on here on upgrading the 60-66 suspension. I know the frames are different on 60-62 trucks than the 63-66 trucks so I was never sure if the 73-87 truck crossmember swapped over on the earlier 60-62 trucks.
I came across the below link on google and figured I would make a post for it so that it would come up in future searches:
Covert 60-62 Front Suspension - '60-'66 Chevy pickups
As you can see, the procedure is the same as the 63-66 trucks. I know 66GMC has done this swap on his namesake truck and I plan on swapping over my 65 c-10 as well in the near future.
Hope this helps any fellow 60-66er's along the way.
NEW INTERIORS 12-22-2012 04:03 PM
It's a very easy swap to do..;)
