60-66 Front Crossmember swap with 73-87 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2012, 01:50 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The question pops up every once in a while on here on upgrading the 60-66 suspension. I know the frames are different on 60-62 trucks than the 63-66 trucks so I was never sure if the 73-87 truck crossmember swapped over on the earlier 60-62 trucks.
I came across the below link on google and figured I would make a post for it so that it would come up in future searches:
Covert 60-62 Front Suspension - '60-'66 Chevy pickups
As you can see, the procedure is the same as the 63-66 trucks. I know 66GMC has done this swap on his namesake truck and I plan on swapping over my 65 c-10 as well in the near future.
Hope this helps any fellow 60-66er's along the way.
Old 12-22-2012, 04:03 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
It's a very easy swap to do..
The Following User Says Thank You to NEW INTERIORS For This Useful Post:
Valkyrie5.7 (12-22-2012)
Front Crossmember Angle 71gtx Suspension - Brakes - Steering 24 01-15-2009 11:44 PM
Front frame / Front crossmember blueprints - feedback needed lowROLLERchevy Suspension - Brakes - Steering 2 09-20-2008 05:46 PM
Need a '55-56 front crossmember johnnyb49 Introduce Yourself 3 09-02-2008 08:51 PM
67 Mustang Front Crossmember Stangman196700 Body - Exterior 2 12-02-2006 08:21 AM
Model a Front Crossmember deathbypontiac Hotrodding Basics 6 12-07-2005 12:08 PM
