'60 Corvette makeover - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-14-2005, 04:36 PM
Last journal entry: 63 split window Corvette RESTOROD
hi, my name is firstgear, aka Herb. I live not far from Norwalk Dragway in Ohio. I have a '60 Corvette that I am in the process of redoing....I bought the car on Ebay from a guy in Maryland.
It came with a tired out 350 cu in Camaro motor from the mid 70's according to the block casting number. I took the motor out and got it over to Ricks Speed Shop in South Amherst, and there Rick transformed it into a 383 stroker. It sits in my garage waiting for the rest of the car to get done.
Right now I am in the process of pulling the body off the frame. The front suspension is being replaced with a Jim Myers Racing IFS with rack and pinion steering, disc brakes and QA1 coil over shocks. Also under consideration is to replace the rear suspension with a 4 bar link tied into a 9" Ford housing also with QA1 coil over shocks and disc brakes.
The tranny is being replaced as well with a Tremec TKO600 (5 speed with over drive 5th).
Car will be painted Corvette C5 Torch Red with White Coves. All of the chrome has to be replated or replaced. This is my first attempt at something of this magnitude.....so be preapred for lots of questions....
Herb
Old 12-14-2005, 05:06 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders, we are glad to have you here.
Installing a Corvette IRS in a 34 Coupe Mc D's 34 Coupe Suspension - Brakes - Steering 12 05-18-2010 12:20 PM
Need Corvette help and info newchevyman Hotrodding Basics 2 11-27-2005 08:44 PM
Corvette Suspension in a 36 Ford lifter Suspension - Brakes - Steering 2 09-04-2005 07:07 PM
Welding Dana 60 D200Dodge Transmission - Rearend 5 02-05-2005 08:30 PM
