60 Thunderbird Suspension Upgrade. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-05-2005, 04:55 PM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
Hi,
I have been reading this forum for a long time and learned a lot of good information. I have a 60 Thunderbird and I want to upgrade the suspension with an air ride system but cant seem to find anything for this car. Does anyone know of a place out there that makes an air bag suspension or something similar? I already did the front disc brake conversion and I just ordered a power steering upgrade from Gearheads Cruiser Products. Thanks for the help.
Rick
Old 08-05-2005, 06:07 PM
aka Duke of URL
Interesting idea. Air-Ride on a SQUAREBIRD....
I see conversions for the front of a 61/66 BIRD. Your rear suspension is leaf (The 58 BIRD was coil) and to fashion an air ride with leaf would be a pain.
Peruse this website- -AIR-RIDE TECHNOLOGIES- and -here- see if there is anything there for you.
I noticed they also offer an airbag similiar in design to a coil over shock. Beautiful! And there are applications for the MUST II conversion.
Old 08-05-2005, 08:10 PM
Sacred Steel
Thanks but I tried Air Ride Technologies and they have nothing to fit my car. I'm hoping someone will chime in who knows of a kit that can be made to fit with some modifications.
Old 08-05-2005, 10:22 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Air ride kits
Sorry I do not know of any inexpensive kits that will fit your car..
Now saying that if you are determined to have the air ride in that T-bird I would look into a 4bar kit with air ride from jim meyer racing or art morrison for the rear and do the front crossmember with the tubular A-arms and rack and pinion on the front..
I know that combo can be made to work just fine but it will require some good fabrication skills and some cash to get done..
OMT
Old 08-14-2005, 01:58 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
60 TBird suspension upgrade
There is a trick new thing out there for leaf Mustangs...... I saw it in the mags for the older Mustangs.
IDEA...... Basicly it is a single leaf semi-rigid quarter eliptic that bolts in place of the forward half of the leaf, and then the rear end is supported by coil-overs. The locating link/leaf acts like a an anti-roll bar and a "ladder-lift bar" eliminating spring wrap up. That's a simple way to put in bags. Sorry, can't find the co's name right now, but it is marketed by one of the BIG Mustang outfits. If I find it I will add another note to thread and email you.
If you don't demand a lot of lowering adjustment, I have seen cutting off the rear of the leaf springs behind the axle only, leaving only the main leaf, and then mounting bags/air shocks to adjust the height. Essentially the same thing as above but using the rear of the main leaf as a locator too.
Old 08-14-2005, 02:02 PM
xntrik's Avatar
disk brakes on 60 bird
Hi,
I already did the front disc brake conversion .
Rick
What did you use?
Old 08-14-2005, 02:30 PM
Sacred Steel
Thanks for the replies. I used the Granada spindles. Here is a link to my write up.
http://www.squarebirds.org/disc_brake.htm
Old 08-14-2005, 08:38 PM
aka Duke of URL
It may interest you to know the 1958 BIRD front (outboard shock absorber mounting) and rear suspension (coil spring) was designed to accept FORD's new FORD-AIRE System. It was also scheduled on FORD-EDSEL-MERC and LINC.
Am Looking For Factory/Aftermarket Speed Parts For The MEL (Merc-Edsel-Linc-TBird) Engine Family (383-410-430-462) Produced From 1958 To 1968
Also Early FORD Special Service Tools
66 Mustang Front Suspension Upgrade trees Suspension - Brakes - Steering 13 06-08-2005 06:12 AM
rear suspension upgrade tuske427 Suspension - Brakes - Steering 4 08-07-2004 12:38 PM
rear suspension upgrade tuske427 Suspension - Brakes - Steering 0 08-05-2004 01:46 PM
1931 oldsmobile front suspension upgrade nomad55 Suspension - Brakes - Steering 2 06-15-2004 06:42 PM
Brake / Suspension Upgrade - 75 Chevy Pickup dwstevenson Suspension - Brakes - Steering 0 12-31-2002 07:42 AM
