600 Or 650 thunder series for this set up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2014, 10:03 PM
ProfitOfDoom's Avatar
Im in the middle of putting a new engine in my car
I bought the Gm 350 H.O. base crate engine ,The specs are here... 350 Crate Engine 330 HP(Base) HO with Iron Vortec Heads 19210007
I know they recommend a 600cfm but I was interested in the 650cfm Thunder series with the adjustable secondaries,but was worried that it would be too much and cause more trouble than it would be worth.
Im using the edelbrock performer RPM intake and will be using a muncie 4sp, Would the 650 be too much carb for the engine and cause some bogging or excessive tuning to get it right,,or would it be ok and work well with my set up?
So im not sure if I should just get the performer 600cfm or the thunder series 650cfm,I'll appreciate Any input or suggestion's... Thanks
Old 03-21-2014, 10:07 PM
vinniekq2's Avatar
I would use a 750
Old 03-21-2014, 10:16 PM
ericnova72's Avatar
More for Less Racer
Won't be much difference between 600 or 650 cfm on this engine, barely a pinch of HP,....but I'd use the 650 AVS for its features if those are the two to pick from.
That additional 50 cfm won't hurt anything (drivabilty) AT ALL. The engine could easily handle a 750 for making peak power.
Old 03-22-2014, 08:32 AM
RWENUTS's Avatar
I'm with Vinnie!
Put a holley 750 vac secondary on it.
If you go with either eddy carbs don't forget to use a fuel regulator as those eddy's don't like more than 5psi fuel pressure.
Old 03-22-2014, 05:16 PM
Ok,Thanks for the help!
I'll have to get a mechanical fuel pump,,,any of those come with a regulator built in,,or just gonna have to run one somewhere in between the line?
Old 03-22-2014, 05:22 PM
RWENUTS's Avatar
You'll need an inline one.
Check here.
http://www.summitracing.com/int/sear...el%20regulator
Old 03-23-2014, 02:01 PM
Check here.
I checked on those 3 and other similar and all the reviews said they are dangerous and either leak right out of the box or soon after. So I dont think I want to chance it with one of those..
Where would you mount something like this? http://www.summitracing.com/parts/nex-15952/overview/
Or could I just skip the regulator and get this edelbrock fuel pump,,says a max of 6psi and dont require a regulator? http://www.summitracing.com/parts/ed...make/chevrolet
That pump is expensive but I guess it would even out if I didnt have to buy a regulator,What do you think?
Old 03-23-2014, 02:19 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.summitracing.com/parts/cr...make/chevrolet
You won't need a regulator with this pump.
Old 03-23-2014, 03:45 PM
That will certainly save some money,,doesnt look at nice but cant say the chrome is worth $100 more.
Looks like it would be the same,but around the same pressure out put,but the summit says 40 GPH Free flow Rate,,and the edelbrock is 110 GPH Free flow Rate,,Not exactly sure what that is?
Old 03-23-2014, 03:59 PM
Wiki Edits: 326
Most modern motors will use roughly 1/2 lb. of fuel for each brake horsepower that is produced over the term of an hour. For instance, a motor producing 300 brake hp over the term of an hour, will use (300 x .5) = 150 lbs of fuel. Since a gallon of gasoline weighs about 6 lbs, the motor will use (150 / 6) = 25 gallons of fuel. This is running 300 hp wide open for an hour.
400 horsepower would look like this:
(400 x .5) = 200
(200 / 6) = 33 gallons of fuel. This is running 400 hp wide open for an hour.
Free flow means that there is no pressure pushing back against the pump, running the fuel from the pump into a large can for instance. This does not happen on a carbureted motor. The needle and seat in the fuel bowl controls the FLOW of fuel by shutting off the flow when the bowl is full. This will make back pressure that can be seen on a gauge as fuel pressure.
If an engine builder uses more fuel pressure than can be controlled by the needle and seat in the fuel bowl of the carburetor, then the needle and seat will yield and allow the fuel pump to blow raw fuel into the intake manifold, creating a tuning nightmare that you may not find unless you're pretty sharp. Carter AFB's and Edelbrock Performers and Rochester Quadrajets work best with slightly less than 5 psi.
Old 03-23-2014, 08:56 PM
RWENUTS's Avatar
Leak!!
I don't think so!
Not the Mr. Gasket one I ran on my 56 for 5 years.
I choose those as an example because of the 1 to 6psi rating. I've found the higher rated ones say from 4.5 to 9psi not able to regulator at the bottom end.
Fuel pump won't help. Regulate it.
Old 03-23-2014, 09:56 PM
Leak!!
I don't think so!
Im sure its like everything,,its either a hit or a miss with quality,,but these are the reviews I read.Cant blame me for being hesitant on using this product...
Amazon.com: Customer Reviews: Mr. Gasket 9710 Fuel Regulator Amazon.com: Customer Reviews: Mr. Gasket 9710 Fuel Regulator
I also looked up the other two and they were about the same
Old 03-23-2014, 10:35 PM
Had another question regarding line sizes.
Im still deciding on if im going with a regulator or not,but I was going to use this fuel line off the carb http://www.summitracing.com/parts/mrg-29883/overview/ ,I picked this one over the edelbrock because this has a port to add a pressure gauge. But I was going to go with this filter that comes with the edelbrock kit... http://www.summitracing.com/parts/edl-8130/overview/
They are throwing me off with the -6 AN sizes edelbrock uses? Are these just another name for the size,I looked up some chart and I think it translates into 3/8 which is the inlet size needed for the inlet of the carb fuel line linked above.
But im unsure,if these are all compatible with each other,or all the AN fittings must be used together and Dont accept NPT type threading.
I was planning on making my own hard line from pump to the end of that filter just wanted to make sure it will work like that?
Old 03-24-2014, 08:44 AM
Last time I bought this stuff I think it was Edelbrock PN 8131 for the chromed hardline with filter (single feed) and the matching kit for the braided hose 8123, which later got swapped out for the black hose (8123 with something on the end - net nanny software won't let me look). Everything fit great. Remember these are soft fittings and need the proper wrench or some kind of padding to keep from chewing them up. One stop shopping.
Old 03-24-2014, 09:59 AM
Leak!!
I don't think so!
I've had great luck with them, never a problem.
I currently use one on the fuel side of a nitrous plate, very handy for dialing fuel pressure to match bottle temp when i don't want to fool with the bottle heater. Works pretty good too, verified by a logging AFR meter.
Secondaries on a Edelbrock 650 Thunder rac43 Engine 14 07-28-2014 03:20 PM
Thunder series missing parts Stormtrooper Engine 9 03-09-2012 07:07 AM
Edelbrock thunder series AVS greenmoonshine Engine 3 10-24-2008 08:36 AM
650 Holley Double Pumper or Edy 650 Thundre Series topdogger Engine 24 08-01-2007 08:12 AM
Edelbrock Thunder Series carb kaddylowrider Engine 1 11-06-2003 02:09 AM
