600 CFM Holley question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2004, 11:29 AM
Jag Daddy's Avatar
1969 Mustang Coupe Project Car
Last journal entry: New Project Mustang, From Jag Daddy to Stang Daddy
There is a guy down the street with a Holley 600 CFM carb for 50.00, it's brand new in the box. Will that be enough for my 400 SBC? Or do I need 650 or better?
Regards
Mark
Old 03-14-2004, 11:33 AM
Erk Erk is offline
I would pick it up no matter if it was for your application or not.
$50 for a BRAND NEW holley 600 is a steal.
If its a built 400 then i would suggest a 650cfm or more..
or as David Vizard said it "If its even mildy a performance application a 750 is the best all around carb you can get"
-Eric
Old 03-14-2004, 11:35 AM
caminoguy55's Avatar
I went through this same drill (only with an Edelbrock) when I started building up my 350sb, and all the advice I got basically said that 600cfm is fine for normal driving, and in fact it is easy to over carb a sbc. I bought a valve and spring kit from Edelbrock, just in case I want to run it richer, but it seems fine.
hope this helps!
Old 03-14-2004, 11:40 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
I would recommend a 750 w/vacuum secondary carb nothing less.
I like Holly but every ones likes something different.
Its your prefferance.
I just sold a #3310Holly 750 duel feed, I rebuilt for $125. w/quick change spring kit.
With the extra $50. get a better carb, why waste your money on the bench.
Luv the smell of NITRO in the morning.
