600 dp holley carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2009, 02:53 AM
tiresmoke55's Avatar
PO-BOYS-TOYS!!
Last journal entry: My new 55 chevy pretty sharp
hello, guys quick question, i just picked up a 600 Holley pumper carb. list number 4776 - 2 And below that i think is the year it was made? that number is 3488.... i need to know if its a 4150 or a 4160 style because i need to order a rebuild kit.....
also when it comes to a 4150 or a 4160 is there even any difference in the carb rebuild kits???
i was needing a 750 DP or bigger carb for a 408 im building but i got this 600 DP in on trade and figured i would have some fun with it,,,, going to try to make it is big as i can w/o spending a ton,,, i was going to cut the choke tower off and smooth all that out,, add bigger jets and jet extension for the rear,, might stick 4.5 power valves or just block off plates in the front and back or just the back.,,,(all depends on what jet size's i go with)
****** also looking for the best HP kit i can get for this carb,, for around the 80 and cheaper price range,,,, i here the AED kits are good???
ANY HELP WITH WHAT CARB I HAVE and what year it is,, would be great. ALSO any extra info on what kit to stick in it,,, AND any other tricks to wake this little 600 DP up would be great also,,,
THANKS FOR ANY HELP GUYS,,,,
Old 02-19-2009, 04:01 AM
DoubleVision's Avatar
AED is just fine. In fact if you call them and give them your numbers they`ll sell you the correct kit.
Old 02-19-2009, 07:28 AM
double pumpers are 4150's and vac secondarys are 4160
your power valve is determined by idle vacuum and cruise vacuum, you cant just throw one in there willy nilly. same with your jetting. something i do with every holley carb i get is fully dismantle it and clean all the casting flash, youd be surprised how much is in some of them. next thing i do is mill the choke horn off (i dont run a street car) then most of the time the linkage that connects the primaries to the secondaries needs to be bent/adjusted to make sure both sides open fully, for some reason out of the box the secondaries seem to only open 7/8. another thing that can be done is to smooth out the butterfly screws that hang out in the way, though its a good idea to locktite them in before you do this. they are swaged at the factory, but when you smooth them out you remove this and it could be possible for it to back out and fall in the engine.
depending on your rpm range, this may not be near enough carb for your application. it will provide great throttle response and low end power, but will run out of air around 5000 or so. if you plan on spinning this thing up to 6500 or so, id go with the 750
Old 02-19-2009, 07:29 AM
racecar100's Avatar
All Dp Holley is 4150 series except the dominator and avenger.
The 4160 is Vacum secondary Holley
Holley Carb Question peteshotrodshop Engine 3 02-29-2008 12:36 PM
Holley 4160 1850 list Carb Question 62galaxiguy Engine 1 03-05-2007 11:46 AM
A carb problem (holley DP) LeadfootBob Engine 3 05-01-2006 03:24 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
holley 600 carb rebuild TheViper Engine 2 09-16-2003 09:52 PM
