600 Holley Vac Secs Advise Set Up On Weiand 6/71 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2010, 03:24 PM
mustang 671's Avatar
hi guys. i am having problems with my set up on my holley 600s vac secs.i have 2 of them on my weiand 6/71 on 351w
timing seems to be ok as i have had it running and have just timmed it up and is within what i have been told on here and also my ecu supplier.
so what jets would you reccomend for primarys and secondarys ?
size power valves ?
i have been told as a rule of thumb to open the mixture screws each side of the metering bklocks by 1 and a half turns to get it running. is a blower engine different ?
i have read about having no choke on so as not to foul the plugs ?
once its all set up whats the best way to start it from cold ?
would higher octane fuel help out ? am running 95 from the pump but saw today there is a garage selling 99 ulitma.
dont want to keep asking loads of questions, so basically what would you do with the carbs and any starting tips.
i have added new jets to the carbs and different power valves and springs so i need to remeber what they were. been some time. prob a year since getting back on it.
thanks guys
Old 10-07-2010, 04:02 PM
holley carbs
have been reading the posts on here regarding the holleys. there is a ball bearing in the carb by the secondarys ? should it be in or out for blowers ? have heard mixed opinions on this ?
Old 10-07-2010, 08:53 PM
I wouldn't run a vac referenced carb like that. Maybe boost referenced secondaries though.
Holley 750 dp basic advise kwazy Engine 4 03-20-2010 10:24 PM
Holley 600, how do I know if it's running lean? hiimed Engine 3 06-15-2003 05:40 AM
HOLLEY 600 4160 CARB QUESTIONS? mr_chickenhead Engine 3 05-22-2003 02:57 PM
Holley 600 vs. 750 jeff germano Engine 6 02-18-2003 09:06 AM
600 cfm holley vs 750 cfm holley 85 regal Engine 7 11-27-2002 06:25 PM
