Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 600 lbs torque 454??
Old 05-10-2011, 12:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
From another thread:
A couple months ago, Car Craft did a test of a Demon Engines crate BBC 4-bolt 454 +0.030" (461 ci), Peanut Port heads (118cc chambers = 9.4:1 CR, stock valve sizes) w/a XE 268H Comp cam (.515"/.520" lift, 224/230 @0.050" duration on a 110 LSA), w/a Holley HP 750 carb and a (too-large) set of 2.25" headers.
It made 446 HP @ 4900 RPM/542 TQ @ 3600 RPM. 490 ft/lbs @ 2500 RPM. There's no doubt the numbers would've been better w/a smaller primary header diameter, IMO.
So, the PP heads are low RPM torquers, for sure. But not total dogs.
That said, the same engine, using a Edelbrock RPM Air Gap intake, Holley 950 HP carb, Comp XE284H cam and a set of Profiler 290cc aluminum heads made 564 HP @ 6100 RPM and 542 TQ @ 4900 RPM.
That's a gain of 118 HP over the smaller cam and heads. The 950 HP Holley doesn't flow anywhere near 950 CFM (said to flow less than a standard Holley 850) and the two intakes are basically the same as well (changed for a better port shape match), so the difference was mostly just the heads and cam.
Using a cam smaller than the 284 w/the 781 heads and a dual plane RPM-type intake and correct sized headers will get you there. The heads should be at least pocket ported and larger valves will help the peaks.
The Following User Says Thank You to cobalt327 For This Useful Post:
OLNOLAN (10-09-2013)
