Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 600cfm or 650 cfm
Old 05-18-2004, 09:43 PM
stepside454's Avatar
stepside454 stepside454 is offline
it depends alot on the rpm you plan to run if you plan to rev it to 5000 RPMs the 600 is just a little small so Id go with the 650. If you plan to go to 5500 I think the 650 is a bit on the small side, but a 1" open spacer might help. If you plan to go to 6000 RPMs youll need more.
