Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 600cfm not enough?
Old 05-09-2005, 07:39 PM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
You know, you could use a larger carb if you wanted to. However, a small carb is not always a bad way to go. You'll get snappy throttle response and you've got enough air to turn it past 5000 anyway.
Remember that the factory 396-325 horse engine had a 585 Holley from the factory. They ran very well with that carburetor. It's better to err on the small side than the large side.
