Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 600cfm not enough?
Old 05-10-2005, 08:27 AM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
To make an accurate carburetor recommendation we're going to need some more specific information about your combination. What it is, and how you're going to use it. I know it can be tough especially when you're young, and just getting started, but you are going to be much better off waiting a little longer and getting the proper piece, then having to purchase another one in the future. Carburetors work on air velocity, so a smaller carburetor will generally run richer on the same combination, than a larger one will. If you have to go one direction or the other the smaller carburetor is a better choice.
