Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 600cfm not enough?
Old 05-10-2005, 08:24 AM
spinn spinn is offline
Originally Posted by NAIRB
You know, you could use a larger carb if you wanted to. However, a small carb is not always a bad way to go. You'll get snappy throttle response and you've got enough air to turn it past 5000 anyway.
Remember that the factory 396-325 horse engine had a 585 Holley from the factory. They ran very well with that carburetor. It's better to err on the small side than the large side.
yep,i put a 600 on my 440 an started it. ran rich, but hey its not gonna be the end. BG's got the fix, to give your fuel a place to mix.
