Hotrodders Bulletin Board
#1
605 box ina 56 Ford
I am trying to sort out issues with my 56 Ford (car) with a Gearheads power steering conversion. It's a GM 605 box and a combo of diff. pitman and idler arms,..... 'sposed to be a "bolt in".
There is an overcenter hard-spot (requires extra effort) when turning the wheel. It's primarily toward one side. I have dropped all the linkage and fiddled with the box adjustment to the point that the "hard-spot" is barely perceptable with no weight on the wheels. However, with weight on the wheels and in a normal driving situation, the hard-spot is still there. I am in a mode of trying to determine whether the problem is in the box, or in the steering linkage. Next, I will attempt to get accurate measurments of the linkage to understand if it might be a geometry problem. I'm pretty sure I understand the geometry requirements. I am bummed after putting considerable time and $ into this project. 'Sposed to be my everyday driver. I would welcome any insights or advice anyone would like to share. |
#2
I got burned by them too
I have a 57 RW ,and installed a GEARHEADS p/s box in it.Was undrivable on the road over 40mph.Went to a rack,problem solved.Look up 57ford/gm605/wanders bad in this .I hope you take the sector out and look at the gear,i feel I know what you will find.You can try to get your money back ,but, I feel they are a ripoff, good luck
Back to top |
Similar Threads for: "605 box ina 56 Ford"
| pictures of a 34 ford PU or simmiler box cab needed | chlsnk | Body - Exterior | 5 | 03-31-2008 08:34 AM |
| Ford Ranger manual steering box ? | AC/DC | Suspension - Brakes - Steering | 12 | 08-12-2006 06:41 AM |
| JAG REAREND INSTALL 56 FORD F-100 | Beedog69 | Transmission - Rearend | 2 | 07-11-2003 05:46 PM |
| Why not 40 Ford stock steering box? | Randy Owens | Suspension - Brakes - Steering | 8 | 01-19-2003 02:59 PM |
| INSTALLING JAG REAREND INTO 56 FORD F-100 | Beedog69 | Hotrodders' Lounge | 0 | 11-06-2001 03:07 PM |
