60's Chevy rearend that looks like a ford 9", please help ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2005, 06:35 PM
New Member
Last journal entry: 1952 5-window Chevy p/u
I have been given a older chevy rear end that is on the narrow side that looks a lot like a Ford 9", does anyone have a clue to what this may be from? It's a 10 bolt on the yoke side and has the numbers GM 23 B157 3725899.
Old 03-13-2005, 07:40 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Can't run the numbers for you but it sounds like the Hotchkiss style 8.2" 10 bolt used in '55-'64 full size Chevies and '62 & '63 Novas. The Nova rearend will have 4 lug axles. Definitely NOT a performance rear end but if it's a posi still pretty valuable to someone doing a restoration. A Posi will have a large "P" cast into the front of the carrier housing.
Old 03-13-2005, 09:16 PM
New Member
It has five lugs and again it's kinda on the narrow side
Old 03-14-2005, 06:08 AM
Hippie's Avatar
Is it leaf or coil spring ? '55-'57 are leaf and '58-'64 are coil. All '55-'64 full size rears were the same length. They are also almost the exact same length as '64-'67 Chevelle, '67-'69 Camaro and '68-'78 Novas. IIRC they should be about 60-1/4" flange to flange.
Old 03-14-2005, 09:19 AM
New Member
It's leaf, so I guess it's from 55-57 generation.
Thanks for all your help. Now I am putting it up for sale.
Charlie
Old 03-14-2005, 10:36 AM
Hippie's Avatar
Almost forgot, '55-'62 Vettes used this rear end also and had leaf springs. Vette maybe ?
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
Removing Ford 9" rearend e-brake cables wp442 Suspension - Brakes - Steering 2 09-01-2004 08:59 PM
67-70 chevy truck rearend width? 68c10owner Transmission - Rearend 2 06-01-2004 01:11 AM
scored a 9" Ford rearend now I need posi.unit shockers69 Transmission - Rearend 3 04-12-2004 10:26 PM
