61 Apache 235/3spd swap for 305/t5 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2011, 07:55 PM
Last journal entry: My '61 Apache 10 project
Has anyone ever tried the 235 swap for a 305/t5 on a 61 Apache? I have the "x" frame, which I think was from 60-62.. I swapped the original front end out for a '86 front end.. crossmember suspension, everything.. I installed the crossmember and noticed that my frame is about an inch shorter than the 86 frame, which means I will have to make a spacer to go between the top of the frame and motor mount. However, I have also seen a person weld the motor mount to the frame and cut off the part of the mount that would usually bolt to the frame, any suggestions for the motor mounts?
Also, what did you do about mounting the t5 transmission in the "x" frame?
'59 Apache to '56 Chev front tin swap Rusty59 Body - Exterior 3 06-07-2009 11:19 PM
Need help with 97 Jeep 3spd auto (30RH) Ghetto Jet Transmission - Rearend 6 05-20-2009 09:36 PM
any 3spd. a 350 turbo ?? dirtslingerrc Transmission - Rearend 7 07-08-2006 09:05 PM
3spd trans. for 72 chevelle ss steven linker Hotrodding Basics 9 05-19-2006 12:35 AM
3spd columne shift to 4 spd SpankyNuts Transmission - Rearend 6 04-01-2005 12:42 AM
