hello, i'm a new member in need of some guidance. 1'm tearing down the rear end of my 61 impala to replace old 336 gears with 370's, everything going smoothly so far, any advise on re-instillation of the axle's, 1 made myself a gear puller to snatch them out, will they go back in without force once splines are lined up. any advice will be appreciated
i meant that i used a slide hammer with an attachment that i made to pull the axles, should i use the same tool to put back in, seemed to be a tight fit, thanks for your help
Related Threads
Hot Rod Forum
2.2M posts
175.9K members
Since 2001
