61 chev rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-26-2005, 03:15 PM
steve t's Avatar
ex biker, now hotrodder
61 chev rear end
hello, i'm a new member in need of some guidance. 1'm tearing down the rear end of my 61 impala to replace old 336 gears with 370's, everything going smoothly so far, any advise on re-instillation of the axle's, 1 made myself a gear puller to snatch them out, will they go back in without force once splines are lined up. any advice will be appreciated
Old 03-26-2005, 05:52 PM
poncho62's Avatar
Wiki Edits: 5
You shouldn't need a puller to get them out. The outer part of the bearing shouldn't be too tight. A slide hammer would work great.
hey should slip right back in too.
Old 03-26-2005, 06:58 PM
steve t's Avatar
i meant that i used a slide hammer with an attachment that i made to pull the axles, should i use the same tool to put back in, seemed to be a tight fit, thanks for your help
Old 03-26-2005, 07:10 PM
poncho62's Avatar
Wiki Edits: 5
Use a rubber mallet to put it back in..................
Old 03-26-2005, 07:16 PM
steve t's Avatar
thanks a lot for the info
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 10:03 AM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 06:32 AM
Dually rear end swap slomotion Transmission - Rearend 5 06-20-2004 10:50 PM
dodge challenger in need of rear end advice. Journier Transmission - Rearend 0 05-28-2004 11:23 PM
rear end traction Junior's67 Suspension - Brakes - Steering 3 11-25-2003 10:23 PM
