61 dodge 8lug straght axle rat-rod gasser
i have a big old ugly 1961 dodge D200 sweepside long bed with a strong 440... this is my first atempt at building a hotrod...... i want the gasser look.. jacked up in the front running 14" rims and a set of old school ladder bars on the rear.. . MY QUESTION IS.... what is the cheapest way to get 14" rims on the front of this monster??? .. . . i wish i could just buy 8lug 14" rims and slap them on the front so i can spend my time building the ladder bars.. the truck stops just fine... can i use 1/2ton spindles and kingpins??? ... i also have 2 mopar parts cars i can rob the disk brakes from if needed..... i am just looking for the quickest way to do this.. mabey wheel adapters for now...... i would think small 14" wheels wouldn`t put much strain on big 8lug adaptors.. ... i want to get the wheels on ASAP so i can start work on raising the springs to the right hight.... i will be asking more questions soon about springs and things and how to build axle blocks.......
THANK YOU
I doubt you can find adapters. To see if the spindles might fit check the part numbers for a set of king pins to see if the 1/2 & 3/4 ton is the same??
The 1/2 Dodge is a 5 lug on 5-1/2" pattern like old Ford pickups and old Jeeps, so 14" may be hard to find in that pattern. |
I didnt know they put any 440 into a pickup or truck until 75. everything else up to that time was 361, 383 "b" engines and the 413 "rb" engine. the 440 DID NOT come out until 1966-67
Those trucks are ugly but they sure are cool at least you wont see one at every corner I found one that Im buying I plan putting some weird engine in it diesel or whatever I can find cheap. You may look at a early ford haft ton truck axle they have disc brake conversion kit for them and lots different bolt patterns for the rotors
THANK YOU
Check with car-part.com on rims as we have gotten tubeless rims for those old trucks from them..the std was or is a 16" tire and rim but then a small 16" tire will look tiny under the front of that truck.These days there are a lot of large tires/wheels that will fit the rear that would give the old gasser look..
Sam
Actually if you were to find an axle from a D100, those use the Chrysler car bolt pattern and I have been told that coronet or belvedere disks will fit those spindles..still leaves some brackets for the calipers to fabricate..
Do some checking on this if you really have to have the 5 lug front axle.. Sam
thanks sam
![]() this is the truck i am going to (Copy) my 440 intercepter will produce about 500 hp... i expetc about the same 1/4 mile ETs as the old barn door...... 100mph runs ALL DAY LONG...lol.. CLICK HERE TO SEE PICS AND STORIES OF THE OLD BARN DOOR http://www.sweptline.com/hist/spectruckshtml |
oops try this link or ckick on (superstockin pickups aLA Dodge)
http://www.sweptline.com/hist/rtest3.html |
The D100 has five lug wheels. What is the difference between the 100 and the 200 front axles and spindles/kingpins?
| Wanted: Rat rod definition | Madd Syntst | Hotrodders' Lounge | 41 | 12-12-2011 04:32 AM |
| stroke to rod ratio | jacobm99 | Engine | 17 | 09-16-2010 10:06 AM |
| 383 vs 350 | TheCiscoKid | Engine | 86 | 05-03-2008 03:10 PM |
| 327 in 88 Truck | pete379 | Engine | 101 | 01-19-2006 09:03 PM |
| longest rods in std deck 454 bbc?? | deuce_454 | Engine | 11 | 01-30-2004 10:06 AM |
