61" split bench for truck? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2011, 07:04 PM
stevekellner's Avatar
I am looking to change up the seating on my 59 Chevy truck and am looking for a donor anyone know what vehicles use a 58-61" wide split bench? I used to have a Dakota, and I can't remember the dimensions but seemed about right. If any members own a "mid-size" truck and are willing to take some measurements, it could benefit others with similar searches to mine. I did a search before posting a new thread and only got fragmented information, maybe we can get dimensions on this thread and make it easier for all who are looking for a bench or split bench set up. Looking for width (driver's outer edge to passenger's outer edge), depth (from front of seat to farthest rear point this might be the seat base or the top of the seat back), seat height (distance from floor mounting point to top of seating surface), and seat back hieght (distance from floor to top of seat back)
Any takers?
Old 08-09-2011, 08:29 PM
pnt4u2's Avatar
Truck seat
I have a 60/40 bench seat I pulled out of my truck to install bucket seats. They are within your dimensions. I don't know if I can list the web site here where I have them listed. Someone let me know and I will put up the link so you can view them. Let me know.
Old 08-09-2011, 09:07 PM
pnt4u2's Avatar
Bench seat
OK, I just posted the seats in the Classified section of Hotrodders Bulletin Board. You should be able to view them there. Hope that will help.
Old 08-10-2011, 07:38 AM
DanTwoLakes's Avatar
Wiki Edits: 22
You can also contact stevekellner via the private message function.
Old 08-10-2011, 10:49 AM
An important distinction I should have made was note if it is a 40/20/40 or a 60/40 split bench. If we can muster a list of seat dimensions in a thread, then it would be easily searchable for all independant of the recipient vehicle.
Old 08-10-2011, 12:29 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
You're right we should. If you have any benches to measure, then maybe you could measure them and post to drum up some enthusiasm.
Old 08-10-2011, 01:41 PM
Wiki Edits: 22
The 60/40 bench seat in my '97 F-150 is 57" wide. The bench in my '79 Chevy is 60" wide. The reason? The door panels in the F-150 stick out farther into the cab. Window to window, both trucks are about 69".
Split "I" Beam Hot Not Rat 1934 Suspension - Brakes - Steering 13 11-27-2009 08:35 AM
60/40 split bench seat Phils56 Interior 8 11-24-2007 09:11 PM
First Body and frame split. Thoughts on "least damage" schnitz Body - Exterior 9 05-06-2007 11:22 PM
removing the backs on a 56 chevy split bench wiseguy50 Interior 2 01-14-2006 08:23 PM
Chevelle split bench vinyl mark2002 Interior 1 05-20-2003 10:01 PM
