62 327 -350 with double hump heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2012, 12:53 AM
what do i do with the hole where the down tube was in the back of block after installing a rpm air gap intake
Old 05-30-2012, 01:04 AM
327NUT's Avatar
Just install the proper size freeze plug it it.
Old 05-30-2012, 07:04 AM
Richiehd's Avatar
JS-70
Make sure you add a proper breather or PCV system to vent the pan
Old 06-01-2012, 12:11 AM
littleknife
there is a small 1/4 in. hole to the side of where the old draft tube used to be on my 327 chevy. Can i install my oil pressure sending unit there? If I run a pcv valve breather does it matter what side of a 600 cfm holly double pumper i attach a vaccum line to? Thanks for the first reply. I am starting 0n getting my hot rod running again.
Old 06-01-2012, 01:03 AM
327NUT's Avatar
Yes you can install your oil pressure sender in that rear hole if it suits your application. The pcv hose needs to be connected to the base plate of your Holley, front or rear, whichever is best. Make sure you have a breather on the opposite valve cover so the air can circulate through your crankcase and up to your pcv.
327 with double hump heads backyard71nova Engine 4 02-13-2007 01:25 AM
350 with 327 double hump heads julioandmaria Engine 2 10-16-2006 04:48 PM
max valve lift for 1967 Chevy 327 camaro double hump heads?? kuhn-77 Engine 1 08-18-2006 07:12 PM
327 double hump heads on a 350 small block rhibbsiii Engine 3 02-19-2006 09:59 PM
Need help Identifying 327 & Double Hump Heads & Holly 63ChevyII Engine 9 09-07-2004 06:46 PM
