62-67 nova/MII install question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-12-2008, 04:15 AM
3rdmember
anybody ever use the MII crossmember ONLY?
not the whole bolt-on stub, just the crossmember?
not doing a nova so don't go down that road, ok?
Old 03-12-2008, 05:43 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Are you asking about an aftermarket M2 crossmember put into the 66-67 nova? Then I would not do it because there does not seem to be any strong metal under there to brace the member.
It's been a long time since I looked at a Nova, but if I was forced to install a M2 in one, I'd think about using a complete stock M2 from a donor that uses strut rods. There may be some hope of finding enough metal under there to make it work.
Basically, an aftermarket M2 non-strut x-member needs heavy steel to attach to, because they are such a p*** poor design. The original Ford setup is properly designed with additional struts to help spread the load forces out over a very much larger area of the uni-body. That's why Ford could use thinner gauge x-members; because the loads are distributed properly. The shops that design & make much thicker x-members and toss the stuts out, are endangering lives.
I will go to my grave dissing the non-strut versions of the M2 kits. They are unsafe. period.
I've had a hard time in the past, trying to explain why just using a much thicker x-member still won't be safe if there are no struts. The best analogy would be cutting a leg off of a chair, and then making the other 3 out of thicker wood
Old 03-13-2008, 03:10 AM
3rdmember
yes, heidts specificly
like i said, i'm not doing a nova....or i would buy the subframe.
and that would be my question.
can i use struts with the crossmember ONLY?
Old 03-13-2008, 03:35 AM
3rdmember
by the way, i don't mean to be a plick about this BUT i'm not interested in "theory" just fact.
IF you haven't done the swap, please don't reply.
i've heard enough BS about strut rods vs non-strut rod fronts.
i'm wanting to use the stock pieces on an aftermarket x member.
btw, F&J, ever heard of a milkstool?
3 legs....
62 -67 nova scratch Hotrodders' Lounge 5 03-07-2007 11:14 PM
Shoulder belt install question. slider in wa Body - Exterior 5 01-22-2003 06:14 AM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
62 imp ss selling question stv Hotrodders' Lounge 1 10-06-2002 03:28 PM
question on cam & oil pump install chev 350 solowookie Engine 16 04-03-2002 04:25 PM
