Thread Tools Search this Thread share on Facebook
  #16
Old 08-09-2011, 03:47 AM
EOD Guy's Avatar
EOD Guy EOD Guy is offline
Good luck in what ever you do, let us know how it comes out.
Register now (free) or login to remove ads
Old 08-09-2011, 06:41 AM
Bryan59EC's Avatar
Bryan59EC Bryan59EC is offline
Car? Truck? Who Cares
Last journal entry: First week of December
Originally Posted by slammedtoys
They also jimmied up the ignition.. They wired the coil to a switch along with a hot on the other side and some black wire that leads from the voltage regulator. The starter is connected to a starter button.. It just seems like a hacked up mess. I enjoy doing wiring projects but looking at this car has me concerned. I have tried to pull the dash out to look behind it but I started pulling it and noticed something was keeping it from coming out so I gave up and pushed it back in.. It was hot and I didnt feel like fighting with it at that point in time LOL
Not sure the whole dash will come out of that car without a torch
As for the ignition----not all that uncommon for someone to wire in a separate button for the starter. The switches are kind of weak.
But, if you are interested, American Autowire will have every harness that car needs-----altho a bit pricey.
Another option with American Autowire is an upgrade wiring kit that will have most of the connections already terminated. Not sure if they have one specifically for your car, but using the upgrade kit for the 59-60 should not be much of a problem to adapt----not sure---you would have to ask Donny B. at American Autowire. If the 59-60 would not be suitable, I believe they have kits for the 65/66 that could also be made to work with a little effort.
I have used AAW products in the past and have beenquite happy. Recently put one of their upgraded harnesses in my 66 ElCamino and that went with little fuss---they even sent me a replacement oddball connector that I had stepped on and damaged for no charge.
Old 08-09-2011, 09:58 AM
helrazr3's Avatar
helrazr3 helrazr3 is offline
im on a highway to hell
Last journal entry: grill and headder panel
the first thing you need to do is get a wiring diagram for the car they are cheap and readily available on ebay once you have that you can go step by step and be sure your doing it right and not just guessing.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "62 Bel Air wiring problems (Tail lights or Head light swtich)"
ThreadThread StarterForumRepliesLast Post
wiring two wire tail lightsdaveidElectrical911-07-2010 03:04 PM
Wiring Tail Lights13DiamondsRod&CustomElectrical103-12-2008 09:00 PM
Tail Light WiringTheresa ShankElectrical1606-11-2007 08:35 PM
tail light/interior lightscrazygutgutElectrical408-26-2005 10:22 PM
EZ wiring harness, tail lights53chevElectrical411-05-2002 06:23 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
