-   -   '62 chevy drive train (http://www.hotrodders.com/forum/62-chevy-drive-train-141916.html)
bigjune62 07-13-2008 05:11 PM
I'm new to building motors, so here goes, My current project is a "62 chevy impala convertible and this is what i've done so far,
bored block .030 over installed stock compression pistons
polished crank and installed new bearings
installed rv cam with advertised int. lift .281 ex. lift .296
duration int. 204 ex. 214
lobe center int. 107 ex. 214
installed a pair of "462" heads with mild port work, hardened seats, port matching.
performer 2101 intake
performer 1406 carb. .5" phenolic spacer
2 inch rams horns port matched to heads opened up to 2.25 at collector flange
2.25 dual exhaust with a pair of magnaflow mufflers (no crossover/ equalizer pipe, kinda hard to do with an "x" frame).
pertronix ignition timing at 35 degrees total advance all in at 2500 rpm.
rebuilt 700r4 trans
new driveshaft with billet center support and slip yoke rear shaft
rebuilt stock rear end with 3.08 gears
24.5" tall rear tires
I'm still working on little details on the car and I'm wondering how this set up should run, I'm making this car strictly a cruiserand trying to keep everything as "stock looking as possible.I failed to mention that evrything but machine work, exhaust and trans. were done in my garage.
59 el camino 07-13-2008 05:31 PM
62
Sounds like a pretty good combo to me. Personally would have put a bit more cam in the engine, however, I tend to like a bit more rump rump. My 59 has a similar 283 with a turbo 350 and 308 rear gears. Just replaced the 454 for economy reasons. Aren't x frames a ***** to work with?
Good cruzin.. John
327NUT 07-13-2008 11:31 PM
You got me on the 5" spacer??? anyway with the 700R4 the best performance upgrade would be to change out that 3.08 and install a set of 3.73's. Calculations show with your tires....3.08 = 2069 rpm
3.73 = 2506 rpm
or even a 4.11 = 2761 rpm ....you would still be able to cruise all day long, my pick would be the 3.73 or something close.
bigjune62 07-13-2008 11:42 PM
that's a .5" spacer, sorry if i mistyped :D
