Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - '62 chevy drive train
Old 07-13-2008, 05:11 PM
bigjune62 bigjune62 is offline
I'm new to building motors, so here goes, My current project is a "62 chevy impala convertible and this is what i've done so far,
bored block .030 over installed stock compression pistons
polished crank and installed new bearings
installed rv cam with advertised int. lift .281 ex. lift .296
duration int. 204 ex. 214
lobe center int. 107 ex. 214
installed a pair of "462" heads with mild port work, hardened seats, port matching.
performer 2101 intake
performer 1406 carb. .5" phenolic spacer
2 inch rams horns port matched to heads opened up to 2.25 at collector flange
2.25 dual exhaust with a pair of magnaflow mufflers (no crossover/ equalizer pipe, kinda hard to do with an "x" frame).
pertronix ignition timing at 35 degrees total advance all in at 2500 rpm.
rebuilt 700r4 trans
new driveshaft with billet center support and slip yoke rear shaft
rebuilt stock rear end with 3.08 gears
24.5" tall rear tires
I'm still working on little details on the car and I'm wondering how this set up should run, I'm making this car strictly a cruiserand trying to keep everything as "stock looking as possible.I failed to mention that evrything but machine work, exhaust and trans. were done in my garage.
