62 chevy truck turn signal - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2006, 04:52 PM
On a 62 chevy truck manual transmission, the turn signal mechanism is in the column and the turn signal switch is located lower on the outside of the column. Between the two is a cable that runs down the column from inside to the switch. I am in need of that cable. I can get the switch and the plug and have the turn signal parts that go into the column, but do not have the cable to connect the two.
Old 10-10-2006, 05:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Confused here, are you saying the Stalk handle has a linkage that runs THROUGH the column to a SWITCH at the bottom of the column, then to a body plug?
OR are you saying the stalk handle is PART or the switch AND a Harness runs between it and a Body plug at the bottom..? (this is the most common) and you need the Column harness?
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-10-2006, 05:31 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
Doc-
The original t/s switch on my 59 had a rod that ran from the "switch area" of the column to the actual switch located near the neutral safety/reverse switch.
I never did look to see how it actually worked--but I think the turn lever actuated the rod and the cancelling cams in the column.
The rod actually ran on the outside of the column (covered by bezels and housings)
(running outside now to check column--cannot check internals--wheel still on)
See pic of 59 column--also man trans--I think his 62 would be the same.
The switch proper is that 6-pin switch--note the cable (I thought it was a rod) from the top to the switch.
Bryan
Old 10-10-2006, 05:38 PM
Bryan59EC's Avatar
If you can find a really small choke type cable---
Lawn mower throttle
Heater cable
(bicycle brake or shift will not work)
You may be able to make something work
Bryan
Old 10-10-2006, 05:41 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Yeah, let me know what you see..I have not run across a "Remote" switch yet..usually the traditional internal harness / Plug arrangement..
Doc
Innovations
Old 10-10-2006, 06:07 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Ahhh..OK..Got it...He's looking for a MECHANICAL cable as opposed to an electrical cable...
Have not run across one of those as of yet..I Learn something new everyday!
Doc
Innovations
Old 10-11-2006, 05:04 AM
62 chevy turn signal
Bryan thanks for the info. I felt all along it was a rod not a cable. Your picture is the same has is on the 62. I will try to come up with some idea of connecting the two. I wish I could come across a book that showed the pictures of how the actuator in the column and the switch on the column connected to each other.
Car 235ci into '53 Chevy Truck New2theart Engine 8 10-17-2006 12:37 AM
looking for a pic - the Navarro (?) families 68/69 chevy truck lowROLLERchevy Hotrodders' Lounge 0 10-03-2006 03:24 AM
Swapping a Muncie SM465 to a TH-350 on a FS Chevy Truck TL-Iguana Transmission - Rearend 1 08-22-2004 05:54 AM
69 chevy truck front end change dragn azz Suspension - Brakes - Steering 4 07-23-2003 01:16 AM
