Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated June 18th, 2009
#1
Crosley
520 edits
#2
Crashfarmer
401 edits
#3
Alittle1
295 edits
#4
Techinspector1
173 edits
#5
Powerrodsmike
157 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 10-22-2003, 07:41 PM
custom's Avatar
custom custom is offline
62 corvette aluminum intake manifold
I have a 62 corvette aluminum intake manifold that has the plenum chamber welded closed between the left and right side. I was wondering if this may have been done in earlier years for performance reasons. If not, can someone tell me why this may have been done.
Thanks
custom
Old 10-22-2003, 07:49 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
1BAD80's barnstarLast wiki edit: Using 400 SBC cylinder heads on a 305 engine
Do you have the part number from the intake?
A picture would be good.
It sounds like someone worked on it, maybe took off the devider to see if it would run better.
Some intakes have a section removed to help the signal to the carb.
I never seen one welded from the factory.
It would probably be from a 327 motor, duel plane.
Luv the smell of NITRO in the morning.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
