-   -   62 ford unibody what engins have the same bolt pattern (http://www.hotrodders.com/forum/62-ford-unibody-what-engins-have-same-bolt-pattern-192910.html)
chford 02-18-2011 02:30 PM
what all engines have the same bolt pattern as the 390 for my 62 unibody and out of those engines what would be the best to make in to a Hotrod?
LATECH 02-18-2011 05:46 PM
you have the late MEL pattern (mercury edsel lincoln)
332, 352, 360, 361, 390,406,410 mercury,427 and 428 would fit.
Not a lot of choices if you were hoping for a little later model engine.
oldbogie 02-18-2011 07:27 PM
The only 2 unibody Fords from 1962 that I know of is the Falcon and Fairlane, not counting the Lincoln.
The Farlane came only with a 170 inch inline Falcon 6 and the new 221 inch V8 which morphed into being called the Windsor block.
The Falcon only came with the 144 or 170 inch inline 6 for 1962 it waited till the next year to get a 260 V8 option.
Both of these cars have platforms are very similar to that of the 1964&1/2 (1965/1966) Mustang. They can fit the Small Block Windsor V8, but the bell-housing bolt pattern changes with mid production of the 289, so the 221, 260 and early 289 thru 64 production use a 5 bolt small pattern while the 65 and up 289 uses a larger 6 bolt pattern, also, common to the 302, 351W and early 351 Clevelands, some but not all M block (351 and 400) engines. The bell-housing, therefore, needs to match the year of the engine. But the engine mounts remain the same across models and time.
The big blocks would not fit without a lot of major platform work to get clearance for their width, the early Falcon and Fairlane are about 3 inches too narrow across the spring towers. Ford stuffed 427's into the 1964 Fairlane, but all of those were custom built race cars. The big block did not become available as a production option till the 1966 Fairlane which is on a different platform than the earlier versions. The Mustang didn't get a wider platform that would accommodate the FE blocks till 1967.
The MEL blocks were never fitted by the factory to these vehicles. Those being the 383 not to be confused with the Chryslers of the same displacement, the 410 used by the Edsel not to be confused with the FE version of the same size, and the 430 used in full tilt Mercs in 58 and 59 and the Lincoln till ending the MEL's run with the 462.
The FE/FT and the MEL do not share a bellhousing bolt pattern except for 1958,59 and part of 60, neither shares a bolt pattern with either of the Windsor patterns.
The 144 and 170 engines have their own bolt pattern it is shared with the 200 till 1977.
200s after 1977, the 250 which is a Falcon block, the 240 which is the big six block and its stretched sibling the 300 all share the Windsor bell-housing bolt pattern.
So to keep life simple you need to have commonality of engine type and in many cases year of engine and bell-housing or transmission, if those parts are of one piece constriction. Sorting out Ford and their bell-housing patterns is more than enough to drive a sober man to drink.
Bogie
toomanyoldFords 10-16-2011 07:12 PM
Ford had a unibody F100 in thous years.
Ford Junkie 10-16-2011 10:44 PM
oldbogie here are a couple of pics of style truck he has...............
http://images1.americanlisted.com/nl...al_9254615.jpg
http://image.automotive.com/f/images...front_left.jpg
These are a couple I found online,
Tony
oldbogie 10-17-2011 06:58 PM
Tony
The F100 Unibody in and around 1962 is a styling option where the bed is welded and smoothed to the cab. Underneath it has a frame. The unitized body trucks were built on the Econoline which uses a lot of Falcon parts.
The F100 used big truck engine options starting with the 223 inline 6, probably most were built with 292 Y blocks, these are different from FE/FT and MEL engines. For his 390, he'd need to use trannys/bellhousings for the FE/FT family which is 332, 352, 360, 361, 390, 406, the FE 410 (not to be confused with the MEL 410), 427, and 428. The early MEL 383, 410, 430 from 1958 into 1960 would work but Ford made a running change on the MEL's so after that they won't bolt without an adapter.
Bogie
