62 galaxie ps options? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 01:51 PM
62galaxiguy's Avatar
I have rebilt the complete front suspension on my 62 galaxie resto and have to do the ps next.I replaced ball joints,tie rods upper&lower control arm bushings idler arm & center link and the steering is sloppy. I adjusted the steering box adjustments according to the ford shop manual and am thinking of going with a Wurth-it design R&P conversion kit. It would cost just as much to rebuild the leaky ram cyl and ps pump, any ideas? mike
Old 09-08-2005, 07:57 AM
willys36@aol.com's Avatar
Wiki Edits: 21
That conversion would ruin your resto if you are going for authenticity. However, if you are after a nice stock looking daily driver, by all means investigate the R&P. Should be pretty easy to identify the source of your slop by crawling under the car and have someone move the steering wheel. The lose joint should stand right out.
Old 09-08-2005, 02:15 PM
aka Duke of URL
The BENDIX P/S System is not that complicated to repair/maintain. Below is a Typical Installation showing most of the service parts. Notice the bushing kit at the end of the cylinder. It is small things like this (and proper setup/adjustment) that will make the system dependable and pleasurable to drive.
-FORD LINKAGE STYLE P/S TROUBLESHOOTING GUIDE-
62 Ford Galaxie Lower Control Arm Question Rattpac Suspension - Brakes - Steering 2 11-05-2008 04:55 PM
Hi there Im Josh with Rudy the 62 falcon RUDY Introduce Yourself 3 01-12-2007 02:55 PM
70 Galaxie GalaxieWarrior Transmission - Rearend 7 07-16-2005 12:34 PM
How raise the back of my 62 Ford Galaxie? unioncreek Suspension - Brakes - Steering 6 04-28-2005 02:26 PM
What tire size on my 62 Ford Galaxie? unioncreek General Rodding Tech 5 03-30-2005 04:28 PM
