-   -   62 Gmc (http://www.hotrodders.com/forum/62-gmc-217706.html)
rambler454 04-02-2012 06:55 PM
62 Gmc
i've heard that a 90s full size truck spindles will interchange with mine? its a 62 gmc short bed and has tourtion bar front suspention. :confused:
Bryan59EC 04-03-2012 06:12 AM
The spindles are interchangeable to 87
Upper and lower control arm swaps are direct.
Buyt since you have a 62, I'm not sure this applies.
Might have to check the pic-up gurus out at:
http://67-72chevytrucks.com/
I do recall reading there that there were some changes that needed to be made with the t-bars
luckynumberslevin 04-04-2012 09:45 AM
60-62 won't interchange with much. I know the arms and spindles won't, I've tried. The simplest way I found was to put a whole clip off a newer truck. On mine I bolted up a 79 front clip. Then u can get Cheep ball joints and common parts. And as well disks
