62 gmc frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2012, 07:46 AM
rambler454's Avatar
Last journal entry: 1968 c-10
62 gmc frame
i got a 1962 GMC short bed all original. i hate the torsion bar front suspension. i bought a 76 Chevy long bed to convert to 5 lug. can i just unbolt the front suspension out of the 76 and bolt it up to my frame? plus the rear on the 76 is leaf so i want that on my 62 as well. would the just be a weld in deal?
Old 07-17-2012, 01:55 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
I hope someone with more experience will chime in, but this is what I have to offer:
From experience I know the that the rear of the ladder bar frame is (if I remember) 4.75" wider on the 60-63 models than the 64-66. I know this from swapping a 62 gmc long bed stepside for my 65 chevy long bed fleetside.
What I don't have experience with, but have heard before is that the front crossmembers of the 73-87 trucks will swap on to the 64-66 bodies with the widening of one bolt hole. I have not performed this swap myself, and did not have the opportunity to measure the 62's front frame when I was doing the bed swap. I would suggest measuring this distance between the frame rails on both vehicles in the front and go from there.
Also, I'm curious as to why you would like to trade the trailing arm setup for a leaf spring setup?
Old 07-17-2012, 02:06 PM
BOBCRMAN@aol.com's Avatar
I haven't done a torsion front frame but the mid sixties frames are an easy, almost bolt in, with mid seventies front suspension.
Old 07-18-2012, 08:44 AM
rambler454's Avatar
i would like to keep my rear suspension it would be nice if the 5 lug axles fit in my rear end housing. or maybe weld my mounts on the new rear end. i don't know.
Old 07-18-2012, 09:05 AM
Wiki Edits: 31
There is a conversion kit for just that. weld on Mounts run about $100 I think. Any of the truck resto sites should have it
frame swap 47 gmc to s-10 frame tom crow Hotrodding Basics 7 10-07-2011 06:11 PM
55 gmc frame clip ? autobuff Suspension - Brakes - Steering 31 07-27-2009 03:59 PM
63 truck cab on a 67 GMC frame? Ranman1822 Introduce Yourself 2 07-14-2006 11:57 AM
46 GMC Frame Dimensions Kermitt47 Suspension - Brakes - Steering 1 11-02-2004 04:53 AM
49 GMC Pickup onto a S-10 Frame 49 lt1 Suspension - Brakes - Steering 12 06-25-2003 08:21 PM
