Originally Posted by JerryK
348 was not available in 62 but will fit the same as 409
Correct. A '61 and '62 are nearly identical as far as brackets etc. so you can use everything from a '61 348 car to drop it in if you don't have '62 409 stuff. Do yourself a favor and replace that '62 cast iron tranny with an aluminum Glide, a TH350 or a 200-4R, the weight savings alone will increase your performance and mileage.
I had a '62 SS with a 283 Glide and was going to swap in a 200-4R, just the tranny swap would have shaved 100 Lbs. off the car.
