62 Impala column shift linkage ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2008, 08:43 PM
I am currently working on the engine and transmission for my 62 Impala column shift automatic. The engine is in the machine shop, I recently bought a 2 speed automatic powerglide transmission out of a 64 Impala . I need help locating parts for my project, When I bought the car it had a Buick 350 engine and a TH350 transmission in it, sold them. Now I need linkage for my column shift + I need a transmission shift bracket from the sub frame to the transmission, I am attaching some pictures of a shift bracket out of a 63 Impala I think might work. THANKS,,,,
ID:	28769   Click image for larger version
Old 03-23-2008, 10:22 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
Im not an expert on this but It looks like the braket and linkage looks the same. if you allready have it you might aswell try it to see if it will work if it dont you can go from there.
Old 03-23-2008, 11:20 PM
Daddy0000h
I don't have the bracket, anyone know where I might locate one. I have looked on EBAY, It has some linkage parts that I can use, but no bracket.
Old 03-24-2008, 09:33 AM
400smb_s10's Avatar
Back Yard Junky :)
Ive done a little bit of searching for ya and all I could come up with is a shifter linkage for a 65-66. heres the link and I hope it helps ya out
http://cgi.ebay.ca/1965-66-Impala-Po...742.m153.l1262
Ed
Changing a Ford C4 floor shift to column, How? RAW Transmission - Rearend 6 01-28-2007 09:47 AM
67 Camaro column shift conversion super_silent Transmission - Rearend 2 07-12-2006 10:08 PM
Restoring Underside of '62 Impala jonestownhogboy Body - Exterior 4 01-27-2006 09:53 PM
62 impala yezek6 Transmission - Rearend 1 04-05-2004 02:59 PM
GM column in a '62 Falcon graig Electrical 0 01-07-2003 02:44 AM
