62 Impala:Lower shock mount, REAR control arm bolt removal. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2013, 09:27 AM
I just went though this removal of both lower rear control arms on my 1962 Impala. First start by spraying rust lube on all nuts and bolts the night before. The forward upper bolts came out with no issue using a 15/16 box wrench on the inside nuts. The lower shock nuts and shocks came off no issue, tie them back out of the way. Now for the shock/control arm bolt. You cannot get a good swing at the bolt with the nut on to protect the threads, or can you turn the shock bolt out. This bolt has a flat spot on the threaded part plus after removal it has a spline on shock side that locks it onto the mount that keeps it from turning. The tool I used, and if you are lucky once placed on the shock bolt and striking with a 5 pound hammer it will break free and pull straight out of the mount. I used the large ball joint fork, it had the 14" handle and fit the shock bolt perfectly flat where it would not damage the shock mount bolt. The fork was placed on the shock mount bolt with the handle coming out just outside the rear brake drum, thus giving a good striking blow to break it free. If it does not come free, you will need to heat (torch) the inside shock mount bolt(spline side)then strike again. You will get it.....remember...time and money fixes all.
Old 06-01-2013, 12:14 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
LennyJay:
Welcome to Hotrodders.
Thanks for the information. You posted to a 7+ year old thread.
Moving thread to suspension forums
Old 06-01-2013, 02:18 PM
Rear lower shock mount info.....
I know it was an old thread...but I looked everywhere just to find out how the rear lower shock mount bolt was held in. It has to come straight out, no twisting or turning. Hope this helps folks, especially when cars come from back east that have road/rust frozen parts.
best cure for mangled lower control arm bolt holes h0trod Suspension - Brakes - Steering 3 04-12-2013 07:33 AM
68 GTO lower control arm removal adam83 Suspension - Brakes - Steering 14 02-13-2011 12:58 AM
Lower Control Arm 71 c-10 Suspension - Brakes - Steering 2 03-29-2007 12:08 PM
1979 chevy k10 lower front shock mount hiball Suspension - Brakes - Steering 2 12-17-2005 08:52 PM
rear upper control arm bushing removal 68chevelle_ss Transmission - Rearend 18 02-06-2005 02:51 AM
