62 Impala tranny linkage troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2005, 03:27 AM
I recentley bought a 62 impala.I'm having a hard time with the kick down rod,throttle cable,adapter kit's ect.locations and so on. Is there a diagram that is detailed.. i got the car pretty much in pieces. 1 of the linkage just spins.I need help Thanks jim.
Old 07-10-2005, 05:23 AM
poncho62's Avatar
Wiki Edits: 5
moving to tranny forum.................
Old 07-10-2005, 11:23 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
not enough information
what adapter kit?
Does the car still have the powerglide? sounds like it does.
which linkage just spins? at tranny? which tranny linkage , inner or outter?
Throttle cable? This year car had linkage , not a cable
let us know what you have , or a photo is worth 2500 words.
Old 07-11-2005, 09:53 PM
i might be able to help u
hey bro, edelbrock sells something that can help you out, not sure what it is called but if you go to your local parts house im sure they can help you out. i had that same problem on my camaro.i
Restoring Underside of '62 Impala jonestownhogboy Body - Exterior 4 01-27-2006 10:53 PM
C4 tranny troubles nastynova Transmission - Rearend 4 03-17-2005 05:38 PM
looking for a 62 Impala dash insert 62ImpalaSS Interior 3 05-06-2004 08:45 AM
62 impala yezek6 Transmission - Rearend 1 04-05-2004 03:59 PM
What's a good tranny replacement for my 62 Pontiac Catalina? Albert Wallace Transmission - Rearend 5 04-10-2002 08:16 AM
