Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 62 Mercury Comet
Old 12-01-2012, 01:59 PM
timothale timothale is offline
Wiki Edits: 27
panel removal
some ford products used a stick on decal over the window crank , and door handles you have to peel it off to get the screw out. then un screw the arm rests. A stiff putty knife or carpenters flat wonder bar nail puller to pry the panel away from the metal door. try to pry near the snap in clips so yopu don't break the hard board backing. I don't think ford used the GM style u clips in those years. IF you push the upholstery panel in, some handles have a u chaped wire clip. HF sells a tool kit. I always used a very small shank screwdriver that the end had been heated and bent into an L shape to pull the GM style clips out.
The Following User Says Thank You to timothale For This Useful Post:
PKyttin (12-01-2012)
