62 Nova Steering box Question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2007, 10:55 AM
ElguapoShoebox's Avatar
Nova Owner
i recently bought a 62 nova and she wont steer side to side ...i felt like i was going to break some thing in the colmn trying to force it. I then pulled off the steering box and found it was completely locked up. So my question is where and how much can i get a new one ... how hard are they to rebuild ... and what else can i pull one out of that will fit in my car? I have a 72 vega and my buddy told me the steering box should fit out of it.
Old 11-22-2007, 11:09 PM
A Vega and a 62 Nova box are NOT interchangeable ...
Old 11-25-2007, 10:59 PM
Nova Owner
any help guys?
Old 11-26-2007, 12:14 AM
http://www.nnnova.com/product_info.php?products_id=2427
Sometimes they have used parts, also.
Old 11-26-2007, 10:25 AM
Always a few on eBay ... usually cheap ... not much demand for them ...
Old 11-26-2007, 05:16 PM
57halfton's Avatar
62 to 66 Nova steering boxes are the same 67 is the first year that had the collapsible column for when you get a accident , you will also need to reuse the pitman arm from the 62 box , I think they are different than 63 to 66.
Some things on a 62 Nova are a one year only then things were improved the next years. My daughter has a 62 Nova , it's been quite a learning experience.
Gene
Old 11-26-2007, 05:25 PM
57halfton's Avatar
Call Andy the Nova Guy 1-818-269-8766
He is near Los Angeles
Gene
Old 11-27-2007, 12:12 AM
Nova Owner
Thanks for all the info guys ... i found a few on ebay ... only one more question how do i get the steering box off of the column? and the pitman arm off the gear box? Ive been trying all sorts of methods with no success thus far.
Old 11-27-2007, 03:25 AM
papa_clutch's Avatar
power hungry
for the pitman arm use a pitman arm puller and for the column take the cross bolt out of the coupler and it should slide off.
Old 11-28-2007, 12:05 AM
Nova Owner
another question i have is what if i took another route and changed out the column and gear box? how would i go about doing this? and what other car could i get a donor column from? maybe a tilt?
Old 11-28-2007, 10:39 AM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
Flaming River sells a bolt-in quick-ratio manual replacement kit for the 62-66 Nova.
Old 11-28-2007, 06:25 PM
Nova Owner
I've seen the flaming river columns ... but i was thinking more along the lines of from another vehicle. I only ask because i know some guys with 60's and 70's chevy pickups were using a tilting & telescoping columns out of some 70's - 80's vans.
Old 11-28-2007, 09:28 PM
57halfton's Avatar
62 to 66 columns do not come off the steering box , 67 Nova's have a rag joint that will separate the column from the steering box. You need to stick with a small diameter column like the stock one not a fat old thing out of a late model whatever with a key switch on it , that just won't look good
Old 11-29-2007, 08:46 AM
Nova Owner
I've seen what your talking about with the box and column not separating .... but then why is it so hard to find one like mine i just keep an eye out on ebay and of all the ones that are listed i only see one or maybe two that have the long shaft that goes in the column?
Old 12-21-2010, 02:06 PM
hey 57halfton, i'm just preparing to drive my 62 nova, and i've run into an issue. i need to replace my steering column because the one currently on the nova, (which i'm not sure if it is even a 62 nova column or not) does not have wiring, or turning signals. i want to replace it with a flaming river 62 nova column, but if the 62-66 box's dont even detach from the column, how do dealers sell columns seperate from the box? and how would i instal the flaming river column if this is true? thanks
Repair a leaky steering box gator412 Suspension - Brakes - Steering 8 06-01-2008 03:03 AM
uh-oh. Wrong lube in manual steering box - what now? hotrodf1 Suspension - Brakes - Steering 6 07-17-2007 09:01 PM
vega steering box question jaredyocum Hotrodding Basics 2 05-31-2007 08:43 AM
67 camaro swap 72 nova std. steering box digger67 Suspension - Brakes - Steering 1 10-14-2006 09:58 PM
vega steering box stiff to rotate pcoghlan Suspension - Brakes - Steering 2 05-28-2006 09:20 AM
