'62 Ranchero Brake steering? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2011, 08:21 PM
I have a '62 Ranchero. I have granada spindals But. After searching options and prices. A person can get granada rotors for about $50 each. Then I find out that s-10 rotors are about $20 and the same problem with calipers.Any ideas like are new ford rotors like ranger fit,and cheeper than grananda? Or maybe other ideas.Also steering will need to be changed. I'm aware of rack and pinion and the '65 Falcon steering is better but mabe other ideas S-10 spindals? Definatly on a budjet. Thanks for any and all help. Ken N.
Old 07-12-2011, 01:07 AM
Wiki Edits: 31
S10 spindles won't work. your best bet is those $50 Granada rotors. It is the cheapest brake upgrade for that body style. You could cross the bearing numbers and probably find another vehicle's rotor to fit the spindle, but it probably won't work with the calipers.. As an example, some Ford Ranger's have the same bearings as some fox body and SN95 Mustangs, but they won't interchange because of the rotor diamater
57 Ranchero power steering?????? jm8541 Suspension - Brakes - Steering 13 02-18-2007 04:22 PM
F250 brake and steering problem 53LEDSLED Suspension - Brakes - Steering 9 08-03-2006 09:16 PM
79 Ranchero Key stopped turning ignition steering lock! Crappie/Smitty Electrical 5 10-17-2005 08:31 PM
Ranchero Disc Brake Conversion TDG Suspension - Brakes - Steering 2 08-14-2005 02:10 PM
55 ford brake and steering swap pzatchok Suspension - Brakes - Steering 7 01-18-2004 02:39 AM
