-   -   62 unibody (http://www.hotrodders.com/forum/62-unibody-233252.html)
brent7727 05-25-2013 06:58 PM
62 unibody
just picked up a 62 unibody f100 with a 400 modified problem is the solenoid is buzzing when I try to start it ? its getting current to the starter but no start? motor came out of a tarino wiring harness to its kinda ****ty thou............ will post pics later any info would be helpfull
vinniekq2 05-25-2013 09:13 PM
cross the solenoid with a screw driver
timothale 05-25-2013 09:40 PM
grounds and connections
make sure all your battery connections are clean and tight, cables to sol and cable to starter, and a good ground strap from engine to frame. if the solenoid is on the fender inner apron that it is a good ground and apron is grounded. Old rusty vehicle can have a lot of poor connections,
