62 unibody - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2013, 06:58 PM
62 unibody
just picked up a 62 unibody f100 with a 400 modified problem is the solenoid is buzzing when I try to start it ? its getting current to the starter but no start? motor came out of a tarino wiring harness to its kinda ****ty thou............ will post pics later any info would be helpfull
Old 05-25-2013, 09:13 PM
vinniekq2's Avatar
cross the solenoid with a screw driver
Old 05-25-2013, 09:40 PM
Wiki Edits: 27
grounds and connections
make sure all your battery connections are clean and tight, cables to sol and cable to starter, and a good ground strap from engine to frame. if the solenoid is on the fender inner apron that it is a good ground and apron is grounded. Old rusty vehicle can have a lot of poor connections,
Unibody cars? 39chevy Body - Exterior 1 08-19-2008 07:53 PM
unibody damage yeepman2 Body - Exterior 5 11-07-2006 06:21 PM
Making a Unibody? TwistedDragon Body - Exterior 16 05-05-2004 06:53 PM
leaving a unibody on jackstands... guumba General Rodding Tech 17 01-19-2004 09:43 PM
unibody nameless General Rodding Tech 2 06-15-2003 03:24 PM
