Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #31
Old 01-06-2004, 08:50 PM
Grant209's Avatar
Grant209 Grant209 is offline
re: 625 Road Demon Jr. Problems!!!!
Originally posted by Tech @ BG
Grant
Glad to hear you got everything working OK. If you're still having problems getting it dialed in once you install the new cam please let us know. www.barrygrant.com
Thanks for the Help....If have anymore problems ill be sure to let you guys know....
Thanks
Grant
Old 09-04-2005, 10:06 AM
cuda66273's Avatar
cuda66273 cuda66273 is offline
Edelbrock carbs?
Do you understand the principles of a carb and how air flow and fuel emusification/atomization relate to power?
The only reason the Eddys work is because of the small restrictive venturi design causing high velocity, once you get off idle their all used up.
Let's not forget the internal cracks and leaks, mid range lean out and poor performance.
Old 09-04-2005, 10:59 AM
malc's Avatar
malc malc is offline
Running on empty
My Speed Demon was running badly and I didīnt find the problem until I was installing a heat shield. To get the shield on and clear the vac pipe for the brakes and PCV I had to raise the carb one half inch.
Before reinstalling the carb I checked the throttle blades and set them right.
Trying to hook up the throttle cable I found it had been holding the blades open just a tad and I had set the mixture to compensate.
I relocated the fixing for the throttle cable and it just slipped into place on the throttle arm of the carb no pulling or binding.
I used two parts of an Edelbrock throttle bracket and bolted them to the original throttle cable position.Raising the cable also made an improvement.
Old 12-30-2005, 07:51 PM
RPMs RPMs is offline
T buckets rule
I had the exact same problem you had. 383 stroker ran perfect for a month then got worse and worse to the point I had raw gas dripping out the headers on the ground. A DEFECTIVE carb found out they left out a plug in the bottom of the carb on the secondary side. This plug missing cause the gasket between the metering plate and carb body to get a tear in it. The longer you run the engine the bigger the tear. The bigger the tear the richer the mixture. I got a new gasket and made a steel plug and it works fine now.
When I contacted BG about this they said yea we have had a few of those.
Like it was no big deal.
I got pictures of all this but don't know how to post them.
Old 12-31-2005, 09:17 AM
XCLR8N67 XCLR8N67 is offline
I have had 2 Mighty Demons, the first one (650) I had absolutely no issues except a little rich at idle, the second one (750) thats a different subject altogether, the carb leaked from the secondary accelertor pump and I replaced that,as well as all the gaskets on that side which it helped immensely, the carb still leaks down but not as bad, I have gone through all the float levels, even lowered them, checked everything for cracks and still cant come up with anything, it runs pig rich at idle and in order for it to idle half way descent I had to turn the Idle Eze out as far as it would go, the fuel pump is the same FP as I used with the 650MD and had no issues, this carb was also recomended by BG for the application. I even called their tech support twice and both times I seemed to get someone who really wasnt as truely knowledgeable as he should of been. We had the engine on the Dyno and kept coming up with little issues of fuel calibration not really staying put as well as what appeared to be an ignition issue. I pulled on the Dyno 392RWHP and 412RWTQ out of my 427sbc on every pull we did after a short shut off we would get out best pull on the first run after that the numbers always dropped as much as 15-25 horse, I have since replaced the Ignition and becasue I dont drive this during the winter I havent really dealt with the Carb. I had planned on pulling the mettering bodies & fuel bowles off of the 650 and putting them on the 750 as well as swapping out all the jets to see if it cures the problem. Maybe the BG tech guy can shed some light on what is going on here.
Old 12-31-2005, 02:53 PM
Tech @ BG Tech @ BG is offline
Technical Support Barry Grant
XCLR8N67,
It's hard to say specifically what is causing the problem you're having with the parts you've changed. Since you're not using the car right now, if you'll send the carburetor back to us we can reflow it for you, and rectify this situation.
Old 12-31-2005, 03:21 PM
Originally Posted by Tech @ BG
XCLR8N67,
Well I guess I will take it off and let it air out so I can ship it back to you, is their a time frame as to how long this should take?
Old 12-31-2005, 03:36 PM
We're going to be a little backed up from the Holidays, so probably about two weeks.
Old 01-14-2006, 05:16 PM
The Carb went out on 1/9/06 you should have it, fix it up right...
Old 01-15-2006, 07:21 PM
LilSmoke's Avatar
LilSmoke LilSmoke is offline
I noticed that no one has mentioned the transition slots.Be sure and recheck where the butterflies are and arent below where they will be into the main at idle.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
