Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 63 biscayne 3 speed overdrive questions
Old 12-05-2012, 06:02 AM
SSedan64's Avatar
SSedan64 SSedan64 is offline
An HEI requires 12V+ to operate, you'll need to replace the stock Resistor wire which drops voltage to about 9V+ for the Points distributor.
Info >> HEI Conversion
Otherwise it should still operate as wanted for the Ignition cut for OD dropout.
