Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 63 biscayne 3 speed overdrive questions
Old 12-05-2012, 10:02 AM
V8&4spd V8&4spd is offline
Last journal entry: It Will Work
The overdrive is operated by a solenoid. Like Poncho 62 says, you can just make an on off switch. A HEI should not affect how the overdrive works if you use a switch to turn it off and on. You could hook up the three on the tree for the 4 speed and use a seperate lever to use reverse.
