Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 63 biscayne 3 speed overdrive questions
Old 12-05-2012, 06:37 PM
Trunkmonkey Trunkmonkey is offline
Thanks for the insight! I assume i would have to run the 12v lead for the HEI from the same source as the resistor wire, other wise the power wont cut when the button is hit on the carb.?? The manual switch sounds like a good idea too.
