Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 63 biscayne 3 speed overdrive questions
Old 12-05-2012, 07:34 PM
timothale timothale is offline
Wiki Edits: 27
switch it
I always rewired my overdrives with a switch on the floor shift lever, Just like driving one of the bigger farm trucks with a 2 speed rear end, Just remember that you can't back up in overdrive. If you stop going up hill in overdrive. it won't roll backward. or if you park it with the overdrive on you will have to turn off the overdrive, go foreward a bit to let it shift out before you can go backward.
