63 Buick Le Sabre Disc Brake Swap
I HAVE POSTED A COUPLE OF TIMES ON DISC BRAKE SWAPS. THIS IS THE ONE I JUST STARTED. THE CAR IS 63 LE SABRE IT WAS 4-LUG 13 INCH TIRES DRUMS ALL THE WAY AROUND.
THE SPINDLES ARE FROM A 78 MAILBU I HAD TO SWAP SIDES BECAUSE IT IS REAR STEER. I USED THE BUNGS FROM A WINSTON CUP CAR. (UPPERS ALL THE WAY AROUND) I HAD TO REAM THE BALL JOINT HOLES AN THE OUTER TIE ROD HOLES. THIS PICTURE SHOWS THE UPPER CONTROL ARM AND A BALLJOINT BUNG IN A PLATE THAT I MAKE. SOMETIMES I CAN RE-USE THE STOCK CONTROL ARMS. I USE THE PLATE WHEN I CAN NOT USE THE STOCK ARM. I'LL POST SOME MORE PICTURES OF EVERYTHING TOGETHER. |
THESE ARE THE FINISHED PICTURES OF THE SWAP. ALL I HAVE TO DO IS THE BRAKE BOOSTER AND MASTER CYLINDER.
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| anyone know of a disc brake swap for 49' ford? | Shoebox49' | Suspension - Brakes - Steering | 5 | 03-05-2004 10:18 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| 3rd Gen disc brake swap | Camaro2Fast4u | Suspension - Brakes - Steering | 1 | 07-07-2003 05:25 AM |
