63 c10 drum to disc conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2006, 10:42 PM
i have a 63 c10 i also have the power brakes and spindles off a 73. can i use these parts by changing the ball joints on the 63 a-arms? and what about the steering components?
Old 01-29-2006, 10:58 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
60-63 Chev/GMC 1/2-tons had torsion bar front suspension didn't they?
My 66 was coil, and I swapped in the complete front suspension clip from a 1976 C10, including the A-arms, spindles, streering linkage, even the sway bar. Well, technically the sway bar is from a 79 C20 ... but I'm quite sure it was the same as the 76 C10 ... just a larger diameter bar.
Have a look at my project journal... this really was quite easy to do, and I'd recommend it as a replacement for torsion bars if it looks possible.
PS.
You're going to have to get some different wheels. The stock ones will NOT clear the calipers.
Old 01-30-2006, 02:20 PM
actually my 63 c10 sets on a 66 gmc frame and suspension so i have coil springs in the front and leaf springs in the back
Old 01-30-2006, 03:09 PM
66GMC's Avatar
Well there you go ... that 73 front clip will pretty much bolt right up.
I just finished swapping out the 5-stud rotors that came with the clip, and replaced them with some 6-stud ones from classic performance. Now I have 6-stud front and back.
BTW, my 66 had coil springs front and rear from the factory.
63 impala simple disc conversion PikFabrications Suspension - Brakes - Steering 21 01-05-2008 03:12 PM
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
69 Camaro Drum To Disc Conversion kellycat Suspension - Brakes - Steering 3 01-16-2006 02:18 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
