63 chev impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2011, 02:13 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
63 chev impala
Is there anywhere in the vin or body tag that tells what size motor and trans was install on a 63 impala 2dr hard top.
Old 03-04-2011, 03:35 PM
poncho62's Avatar
Wiki Edits: 5
There is a tag on the firewall, down by the steering column......Put those numbers in here.....
http://www.1963chevrolet.com/chevycowl/index.asp
Not sure if taht will give you engine info or not.....If not, you need to take the numbers off the engine block.....explained here
http://www.nastyz28.com/sbchevy/sblock.php
69 chev impala dash bulbs 327 / 350 hp Electrical 2 05-24-2010 06:36 AM
Switching 63 Impala to 64 Impala heat control dmaggard Interior 2 09-13-2006 08:17 PM
Has anybody used a Chev Astro van booster/master cylinder for the 48 chev truck tomy2tone01 Suspension - Brakes - Steering 2 04-07-2003 06:05 PM
1961 chev impala BlvdKing Hotrodders' Lounge 1 07-26-2002 07:13 PM
1961 chev Impala bubble top 348 tri power David McConnell Engine 3 11-08-2001 12:31 AM
