63 chevy front susp swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2003, 09:39 AM
Post 63 chevy front susp swap
i swaped my front suspension in my 63 to a 81 chevy 1/2 ton (unbolt the cossmember on your old one and bolt up the 81 to 88 front suspension youll have to redrill a couple of holes)any way what would be a good brake system.master cyl,brake booster,etc.it also has rear disc brakes out of a 79 lincoln
Old 03-09-2003, 09:46 AM
roys63's Avatar
Post
You bolted this into 63 PU not a car ?Right?
Old 03-10-2003, 08:21 PM
Post
yes sorry for not making myself clear on that its a 63 chevy 1/2 ton shortwide big backwindow pickup
[ March 10, 2003: Message edited by: slip ]</p>
Old 03-13-2003, 07:06 PM
74huggerorange's Avatar
Post
Use the brake booster and master cylinder out of the truck you got the front end out of the get a proportioning valve because disks require alot more pressure and you dont want the low pressure that it would be sending to the used to be drums. My buddy does that type of crap like that for people all the time just north of you in waukomis
Old 05-01-2003, 09:20 PM
New Member
Post
is it possable to buy 6-lug rotars 4 a camaro clip try ing to put under 60-66 gmc w/o changing wheels
